Mission Expression Pedal With Switch For Helix
UPC: LIN-O-990403605
Price: $139.00
The Mission Engineering SP1-L6H switching expression pedal gets the most out of your Line 6 Helix Rack.
The linear potentiometer is matched exactly to the specifications of the Line 6 Helix for a precise and natural response. The pedal has a toe switch to turn effects on and off without requiring a separate footswitch.
The SP1-L6H can be connected to inputs on the Helix Rack or the Rack floor controller.
The Mission SP1-L6H connects to the Line 6 Helix Rack or Rack controller with a single TS cable for expression, and a single TS cable for the toe switch. TRS cables are not required for Line 6 expression pedals.
The toe switch function is only supported on the Helix Rack and Rack controller. Other Line 6 devices do not have a toe switch input. The switch output may be left unconnected if this function is not required.
The Mission EP1-L6 is recommended for other Line 6 products where a toe switch input is not available.
Pedal dimensions are 10″ x 4″ x 3″
Weight is 3.2lb
Potentiometer is 10K Ohm Linear
Switch is TS Momentary
